Group 20-30 management zones into 1 management zone
divyangsinghal1
Visitor
The ask here is, we need to club 20-30 management zones into 1 management zone, to pull out data for the customer.
If this can be achieved in some way by creating a new master management zone where we can add the other 20-30 management zones.
Please suggest.
Divyang
5 REPLIES 5
AntonPineiro
Maybe you can base management zone logic base on tags. Entities can have more than one tag, it means, it can be tagged with "mz1" and "global-mz", same with "mz2"... Then, entities with "global-mz" would be entities in "mz1" and "mz2".
Best regards
radek_jasinski
You can also make one Management Zone that will contain rules that map components from other MZs. For this, I would use an API with which you take the configuration from the Management Zone and create a new "global" one based on it
https://www.dynatrace.com/support/help/dynatrace-api/configuration-api/management-zones-api
Radek
Have a nice day!
AntonPineiro
A product idea has been raised about this topic.
Hi Anton,
Thanks for raising a product idea.
Actually i have also already raised a product idea for the same: Grouping multiple management zones together into 1 master management zone - Dynatrace Community
It means, I had just linked your product idea, I had not created a new one.
Best regards
