Options
- Mark as New
- Subscribe to RSS Feed
- Permalink
‎09 Jun 2020 07:49 AM
How to read code level on purepath,
I am very confused how to read it,
For elapsed time, self time, and duration
Labels:
- Labels:
distributed traces classic
Options
- Mark as New
- Permalink
‎09 Jun 2020 09:48 AM
- Elapsed time shows the time the instrumented point in code started execution (calculated from the beginning of the purepath, so first entry will have zero time)
- Self-time shows the duration of the code itself (the instrumented row), excluding subcalls
- Duration shows the duration of the code itself including subcalls.
Not the solution
Reply
Options
- Mark as New
- Permalink
‎11 Jun 2020 10:37 AM
Hi Julius L,
Thanks for your answer
ANP
