Monitoring Denodo using Managed
ravikumar_dhand
Newcomer
Wondering any of you monitoring the Data Virtualization application called Denodo using Managed and share your experience.
4 REPLIES 4
laurens_devocht
Newcomer
Hello @Ravikumar D., we are struggling with Denodo in Dynatrace.
Denodo is not recognized as a database, but in fact we use it as a database with an ODBC connection from our application.
bill_scheuernst
DynaMight
DynaMight
I am new to Denodo and was recently tasked to use DT to monitor Denodo.  Not knowing the technologies used in Denodo, does One Agent support this?  We are using DT SaaS.  Can anyone share their experiences or knowledge on this?
gary_carr1
Dynatrace Advocate
Dynatrace Advocate
This may be helpful for integration. The link I am sharing is from 2016 and was referencing the older Dynatrace AppMon platform.  So the steps will not work as documented but I am hoping the content is helpful as a starting point for use with latest Dynatrace. https://community.denodo.com/kb/en/view/document/Using%20DynaTrace%20Application%20Performance%20Man...
bklein
Newcomer
For monitoring the Denodo Data Virtualization application using Managed, you can explore various options available in Denodo's documentation and Community Knowledge Base. Check out the Denodo official documentation for detailed insights on monitoring: Denodo Documentation. This resource will guide you through the available monitoring tools and techniques.
Hope it helps!
