OneAgent connection issue with Managed node
sumitkumar
Newcomer_
Dynatrace OneAgent failed to connect to Dynatrace Managed cluster node.
When I deploy OneAgent in Windows, all services are shown, but there are no log records.
Mohamed_Hamdy
DynaMight Leader
DynaMight Leader
Hi @sumitkumar,
this could be due to multiple things, if you are sure that the log file (C:/ProgramData/dynatrace/oneagent/log/os/.....) is empty with no logs, you can try to reinstall it again but after uninstalling and removing the old configurations and restarting the server, and if the log file still has no logs you can open a support ticket but most probably you will find the reason in the logs.
Best Regards,
Mohamed
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
radek_jasinski
It would be very strange if you don't have log entries after installation. Verify that you are checking in the correct path - see what @Mohamed_Hamdy  wrote
Have a nice day!
