HannahM
Dynatrace Leader
Dynatrace Leader
Self Service Summary
Sometimes a simple click is not sufficient and a right-click is needed. This can be achieved through a JavaScript Event.
Issue Solution Tasks Alternative(s)
Right-click is needed Use a JavaScript event Find the relevant locator
Update the snippet
If this does not work, you can ask on chat to check your code.
Steps to follow to perform a right-click in a Browser Clickpath Synthetic Monitor
  1. Go to the relevant page in a Chrome browser
  2. Right-click on the element which you want to interact with on the page and select Inspect. The element will then be shown in Developer Tools Inspect.png
  3. Right click on the element on the Web developer tools - > Copy - > Copy JS path
  4. Paste the JS path on the below element value
    function rightClick(element){
      var evt = element.ownerDocument.createEvent('MouseEvents');
      var RIGHT_CLICK_BUTTON_CODE = 2; // the same for FF and IE
      evt.initMouseEvent('click', true, true,
          element.ownerDocument.defaultView, 1, 0, 0, 0, 0, false,
          false, false, false, RIGHT_CLICK_BUTTON_CODE, null);
      return !element.dispatchEvent(evt);
    var element = document.querySelector('button[id="testid"]'); //Replace with the element which you want to right-click.
    rightClick(element);
  5. Add a new event into the monitor, where you need to right-click and paste in the updated snippet above.
Version history
Last update:
‎02 Jan 2024 10:00 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks for sharing!
