adham_sabry
Dynatrace Organizer
Dynatrace Organizer
Following installation of OneAgent, your Apache web server must be completely restarted to enable monitoring. To do this correctly, it's important to understand the difference between "partial" and "complete" restarts. In the case of partial restarts, the main Apache process re-reads its configuration files, re-opens its log files, and then restarts its worker processes. OneAgent however, requires a complete Apache web server restart in which all workers and—most importantly—the main Apache process are shut down entirely and then restarted.
See Stopping and Restarting Apache HTTP Server for more information on the different types of available restarts.
To perform a complete restart:
  • Linux and AIX
    • You may be accustomed to restarting Apache by issuing an
      apachectl restart
       command. However, this command only results in a partial Apache restart.
    • To execute a complete Apache restart and enable deep monitoring with Dynatrace OneAgent, you need to first invoke a complete shutdown using the
      apachectl stop
       command. Only following this step can you restart the server using
      apachectl start
    • It's fine to use
      service apache2 restart
       on Ubuntu systems. Note however that whatever commands you use, you'll likely need superuser rights (sudo).
  • Windows
    • On Windows, you can either use the built-in Windows Service Management or Apache Service Monitor (httpd.exe) to restart Apache services. Restarting the Apache service with Windows Service Management guarantees the complete restart. With httpd.exe, you may be accustomed to restarting Apache by issuing a
      httpd.exe -k restart -n "Apache2.4"
    • To execute a complete Apache restart and enable deep monitoring with OneAgent, you need to first invoke a complete shutdown using the
      httpd.exe -k stop -n "Apache2.4"
      httpd.exe -k start -n "Apache2.4".
Version history
Last update:
‎01 Nov 2022 05:58 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
And if all else fails, restart the entire box 🤣 Thanks @adham_sabry for providing clarity on this issue and the solutions that are available to us 🙂
