In the custom.properties in the gateway configuration files directory:
[com.compuware.apm.webserver]
port-ssl = 9998
port = 9999
port-ssl = 9998
port = 9999
Hello @Julius L.
I will have to copy the following entries as it is in the custom.properties file?
port-ssl = 9998
port = 9999
Babar
Hello @Julius L.
At last, I got the following:
missing querystring
Below is the current status. How to resolve internal users of web applications issue?
Babar
My guess is that the URL provided is not reachable from the cluster node and it might be OK in your case.
I’m not sure how Dynatrace validates this option.
Can you try if you can reach the /mbeacon from your internal network?
This might be also a DNS issue since in enterprises domain resolves different records internally than externally. Just validate from your PC in the internal network if you can reach the URL. Might be just the case the hostname is even not propagated to internal users.
Hello @Julius L.
The internal DNS already has done for F5 and Cluster ActiveGates even though internal users of web applications (for agentless real user monitoring) is not resolving.
Babar
Is the https://dynatrace.domain.com/mbeacon reachable from a browser in the internal network?
Can you do
curl -v <a rel="noopener noreferrer nofollow" href="https://dynatrace.domain" target="_blank">https://dynatrace.domain</a>.com/mbeacon
from your cluster node? If your dynatrace cluster is using proxy, you must specify the proxy with -x curl argument.
I believe the verification is done from the dynatrace managed cluster nodes and it fails for you. Maybe just the external URL is not reachable from your cluster node.
Hello @Julius L.
I requested to open the port from my PC to the URL to check the /mbeacon result.
Below is the curl command output from one of the Dynartrace Cluster Node.
Babar
This looks like your proxy is talking to the non-SSL port now with https.
Hello @Julius L.
I configured the non-ssl port for the Cluster ActiveGates to avoid the certificate issue.
Babar
After the change you need to reconfigure the F5 to make a http call instead of https.
Hello @Julius L.
We already have done these changes and Synthetic monitoring started successfully.
Now the only pending thing is the following:
Babar
Hello @Julius L.
What could be the reason for the intermittent test connection to URL Passed/Failed?
Babar
As I have written before - you changed the activegate port and now the F5 is talking http to your https endpoint.
Hello @Julius L.
Apologies. I could not explain my point well. F5 is reconfigured to talk to the Cluster ActiveGates on Port # 9998 instead of 9999. In the same way Cluster ActiveGates, also configured for the non-ssl traffic to accept.
We started collecting Synthetic data with up and down status e.g. in the below screenshot you can see the grayed-out area for all the locations and I am unable to understand the meanings of No data legend, therefore, I also opened a different question for the same subject to discuss for better understanding.
The strange thing is that availability is showing 100% for all the locations even with almost half of the grayed-out area.
Babar
Hello @Babar_Qayyum,
As I am browsing for a solution here, I came across your situation and its as mine currently so if you could recommend the changes that have been applied to fix this.
for now, I only changed the custom.properties file since its something can be done from my end and I got the following URL results :
/mbeacon
missing type parameter
I want it to be for both Mobile RUM & Synthetic Monitoring, so any idea on what might be missing here ?
Load balancer configuration:
Frontend HTTPS
Backend is 9999
Hello @Reef
Did you get a chance to look at the below deployment models?
https://www.dynatrace.com/support/help/shortlink/managed-deployment-scenarios
Babar
Hello @Reef
Thanks for the information. If you have configured it accordingly then try a Synthetic Monitoring test. I can share my personal experience that you should not care about the below test results.
Babar
Hi @Babar_Qayyum,
Got it, so test results doesn’t matter on this but unfortunately its still not working.
So why I felt the similarity with the situations, its because after having the following
response ERR_RESPONSE_HEADERS_TRUNCATED from my domain name I’ve added the ports to custom.properties file and restarted the service, somehow its seems worked for a bit as the follow :
but I couldn’t figure why it was only for a bit, as currently no data is available after that time and Synthetic seems still not working.
Hello @Reef
Is the fallow of traffic LB 443 > Cluster AG 9999?
Did the network/LB team configure the above configuration accordingly?
Also, please have a look at the below link:
Babar
