Databases & Services
Is that server making calls to database for sure? Which database framework is being used? You can see database frameworks supported in Technology support.
Best regards
yes for sure its making a call to DB server and using mysql
But which database framework? Have you check Java / .NET / PHP database frameworks in my before link? It is to be sure it is supported by Dynatrace.
Best regards
MSSQL15.MSSQLSERVER
.net, CLR, Microsoft SQL Server and My SQL version is 5.7
Database Framework for .NET is ADO.NET:
Are you using that? If you are using that to connect to database, database services should be discovered.
Best regards
Would you be able to share this snapshot again after the process restart is completed.
