The names are perfectly fine. One more thing I noticed is that these queues are not those queues monitored by IBM Message Queue Java (IBM Extension).
How to make sure that the queues will be tagged only belonging to the IBMExtension?
I think then you may want to change the selector to type(custom_device)…
But for custom devices there is an extra entry (like for hosts, process, services..)
Which you can also use to apply dynamic values(placeholders) to the entities.
Hello @mark_bley
Let me go through with all the possible options and then I share with you the results.
Babar
