Download and Set Up Dynatrace Demo Application
Hello, the same thing happened to me with these two servers, can anyone tell us which versions of Linux are compatible?
Getting this:
Server 1
sudo /bin/bash installChromeDeps.sh
Sorry, Ubuntu 22.04.1 LTS is not supported.
Server 2
./installChromeDeps.sh
Sorry, AlmaLinux 8.7 (Stone Smilodon) is not supported.
Thanks :frowning:
Hi.
I looked into that script and I can say that the Linux versions we currently support are:
  • debian 9
  • debian 10
  • ubuntu 16
  • ubuntu 18
  • ubuntu 20
  • centos 7
  • centos 8
Hope this helps :sweat_smile:
I edited the script and added my version in.
I worked for me and I haven’t seen any issues so far.
Hi team,
Should you disable monitoring on com.dynatrace.easytravel.weblauncher.jar? I don;t see com.dynatrace.easytravel.launcher.jar running in my test environment.  Kr Ian
Hi Ian,
Yes, please disable monitoring of webaluncher.jar process.
I updated information on page.
Hello Dynatrace Team,
Currently, the link to download easyTravel is giving me an error of not being able to access the page to download. Not sure if it is something on my end or your end.
Any help is appreciated. Thank you.
Austin
Well … I just tried to download both the windows and linux installers and both downloads work correctly for me.
Can you try one more time? If that does not work, then there is an issue somewhere.
Well, when I go to the website now, it shows the list of installers. Before, it would show me this long url link that took me nowhere. Nothing changed on my end except turning off my PC for the night and then booting it back up this morning.
It seems someone else in my team fixed this and forgot to tell anyone about it… So yes, you are right. There was a problem and it was solved. Thanks for info!
Small update in supported versions. Ubuntu 16 is dropped as it does not support Chromium 90+. But we support ubuntu 22 now. So the updated list is:
  • debian 9
  • debian 10
  • ubuntu 18
  • ubuntu 20
  • ubuntu 22
  • centos 7
  • centos 8
Well, that is all from me 😉
Hi, another method that worked for me was installing the new version for Linux easyTravel with Docker. A full tutorial can be found here.
Thank you. The original post still says
“You should disable monitoring of launcher (com.dynatrace.easytravel.launcher.jar easyTravel (x*)) and weblauncher (com.dynatrace.easytravel.weblauncher.jar easytravel-*-x*) processes”.
I assume that now turning off deep monitoring for weblauncher.jar is sufficient, correct?
Here is how to handle dependencies for RedHat:
sudo dnf groupinstall workstation
sudo systemctl set-default graphical.target
sudo yum install java-1.8.0-openjdk chromium firefox screen
sudo reboot
You can just install firefox and chromium manually and skip installChromeDeps.sh, I am running easyTravel on RedHat without any issues.
Correct. You just have to turn it off for the one you are using and you can find in Dynatrace.
Depending on the way you start easyTravel you will have one “*launcher” jar file monitored - if you don’t disable it’s monitoring you won’t get any RUM data. There are a few ways/scripts to start easyTravel and they may use different “launchers” :slightly_smiling_face:
While creating the session in the easyTravel application the Payment Backend (.NET) and B2B frontend (.NET) is not running. How can I solve it?
Hi.
Well, it is hard to say what is wrong. So let’s go with the flow:
  1. Well, I assume that your problem is that when you start a scenario in easyTravel then 2 of the services don’t start or crash and are gray, correct?
  2. I assume that you are running easyTravel on Windows - otherwise it won’t work.
  3. I assume that during the installation the checkbox for IIS installation was checked - otherwise it also won’t work.
  4. I guess that you tried to stop and run it all again and the problem persists and repeats, right?
  5. Can you check you IIS setup? There should be:
    1. 2 extra pools: “dotNetBackend_easyTravel_x64” and “dotNetFrontend_easyTravel_x64”
    2. 2 extra sites: “dotNetBackend_easyTravel_x64” and “dotNetFrontend_easyTravel_x64”
    3. By default the sites should be up and running just like that, so you should be able to visit these services at:
      1. http://localhost:9000/ - the frontend - you should be able to see the page with tiles, but if you click on one of them and try to log in it will fail if easyTravel is not running
      2. http://localhost:9010/ - the payment service
  6. I assume that in the scenario you have started the “Payment Backend (.NET)” and “B2B frontend (.NET)” are both grey - stopped.  Did you try to have a look at the logs - they are located at “C:\Users\YOUR_USER\.dynaTrace\easyTravel 2.0.0\easyTravel\log”? I suggest looking through:
    1. B2BFrontend_9000.log
    2. PaymentBackend.log
    3. WebLauncher.log
  7. Did you try to restart the stopped “.NET” processes? To do that click on the grey process box and select “Start”. Did it turn on? If not did something appear in the logs?
So … this is all I can think of right now. Can you look through my suggestions and say if there is anything out of order that you have noticed? If there are no discoveries then please tell me:
  1. What version of windows are you using?
  2. What version of easyTravel are you running?
  3. Did you change anything during installation?
  4. How did you start easyTravel?
  5. Which scenario are you running?
  6. Did you overwrite any config settings anywhere?
Hope these will help us recreate the problem.
I have followed all your suggestions but the problem persists.
I think the problem is due to the fact that ports 9000 and 9010 are occupied by another application. As you can see from the window that appeared when I reinstalled the application.
Regarding the previous questions: I have windows 11, the version of easyTravel is 2.0.0.3551, ,I didn’t change anything during the installation other than the checkbox for IIS and I ran the standard scenario, but the same problem occurs with the others.
Do you think it is the port? How can I solve it?
Hi.
Well, if the ports are in use by a different application then that probably is the main cause of the problem. You can double check by going to you local addresses and checking if you see our easyTravel stuff or not, I mean trying to go to:
But I guess these won’t work. So I have 3 solutions for you:
  1. Find out what application uses those ports, stop that app, restart easyTravel and check if it works.
  2. Create a VM somewhere and install easyTravel there.
  3. And the harder option. So rewire easyTravel. You can modify the easyTravel settings by going to file “C:\Program Files\dynatrace\easyTravel (x64)\resources\easyTravelConfig.properties”. There modify the following lines:
    config.paymentBackendPort=9010
    config.b2bFrontendPortRangeStart=9000
    config.b2bFrontendPortRangeEnd=9009​
    Set a different port for PaymentService and Frontend. Just set the same value for range start and end of frontend. Apart from doing this, you need to go into the IID applications and rebind them. Restart the sites in IIS as well. After that restart easyTravel. It should work.
sudo reboot
You can run weblauncher.sh from terminal without GUI, but it needs to be installed so the chromium process can use it.
