Extension 2.0 - where does the logic go?
Thanks once again. My quest started as a simple one. When I go to https://www.dynatrace.com/hub/detail/microsoft-sql-server-2/?query=Microsoft+SQL&filter=all - this then asks me to choose free trial. then I enter my email and then it logs me direct to our dynatrace instance (since we have SSO) and then I am never able to download the extension.  In the extension 1.0 case I used to be able to download it. Any idea?
Do you not see the download link as per the image here?
You select Release notes, newest version and click download?
Looks good. Thanks
Hi @Mike_L still on schedule for OA/AG 1.283, cluster 1.284?
Yes, unless @michal_nalezin heard that it changed during Christmas. (I was off).
@michal_nalezin Any updates regarding this?
Sure, we needed to move it by 1 version, so it launches with OA 1.284
We are including a Certificate Revocation List, to ensure that certificates can be easily, although manually, revoked in case of security issue.
Meanwhile, we are did allow some customers to use it already on a preview basis.
Reach me directly if that’s your case, but since this is a week of Perform, we may observe some delays.
Best regards
Michal
GA of custom python extensions has been postponed to OA/AG 1.285, cluster 1.286
