Generix Linux Commands extension frequency
Great thnx, I know we will migrate the functionality before October. Just need this to buy some time.
BR Martin
Any updates on this? We too are trying to find an alternative that is safe but somewhat similar to the previous functionality.
Hi Community
The link with more information about the migration to Extension Framework 2.0 is this > Unmatched scalability and security of Dynatrace extensions
The Linux Command extension will stop working from 2 Factor ActiveGate and Dynatrace SaaS
With version 1.301 of both ActiveGate and Dynatrace SaaS, this extension will no longer work.
I suggest you could create a Dynatrace ticket, so a workaround can be evaluated. :flexed_biceps:
I hope it’s helpful :flexed_biceps:
See related idea : RFE: All extensions delivered by default with customisable polling frequency
