How to add a multidimensional analysis chart to a dashboard?
For tracking two level exists :
- At Application level (RUM : User actions) ==> Marked as Key user actions
- at Services level (Web requests) ==> Marked as Key Requests Monitor key requests | Dynatrace Documentation
About request attribute : it is used as key/value pairs that are associated with a particular service request (eg. capture metadata). You can for instance capture a specific parameter from a header request thanks to request attribute and apply as filter. But this operation would be limited to Process Group.
Moreover, if you want to track requests “flow” (one endpoint to another) , you can do it via Service Flow.
Hope it helps.
The application I’m referring to is an API.  It receives calls from various other applications.  I would like to be able to get response time/failure rate/etc. metrics for all requests calling these APIs split by where its coming from to be able to view this on a dashboard.
Service flows and MDAs can currently show me this information, but I would really like to have this available on a dashboard.
@John_McLaughlin at the moment this is not possible MDA and ServiceFlows work on the service request level data (PurePaths), not on metrics data which can be pinned on dashboards. You can create calculated service metrics for your API service, unfortunately it’s not possible to have a filter on calling or called services due to the nature how trace data collection works.
However, if you are able to filter your requests on your API service based on some other criteria such as Request Attribute, then you will be able to do it using calculated service metrics.
