Updated Env and Cluster to 260: Github Release Link
Thanks for keeping this updated.
@pahofmann thank you for maintaining this and please keep posting as you make updates. This is a very useful solution you’ve created here.
Thanks, always nice to hear. Will do.
Update to Environment 1.270 and Cluster 1.268: Github Release
Updated to Environment/Cluster 1.274: Github Release.
@pahofmann Firstly thanks for this its to truly helpful. Is there a way I can get the metadata / manifest file for the API’s. In OCI DI you have to create a REST API task that requires you to add a json or yml manifest file for the API you calling.
Great to hear it helps. Sorry for the late reply, I was on vacation ![]()
You can download the OpenAPI Spec file for the dynatrace API directly from your environment.
Just go to the API browser (via person icon on the top right), there you have the option to download the spec.json:
Updated to Environment/Cluster 1.290: Github Release.
So usefull! Thank you for your job!
It’s been a while, updated to Environment/Cluster 1.296: Github Release.
Updated to Environment/Config 310 and Cluster 308: Github release.
Updates to Version 320: Github Release
There also is a Bruno version now that can be found here.
