“12183 - The site reported HTTP_RESPONSE_CODE_FAILURE” is a generic error which you need to check further into. It’s alerting you to a status code that is not considered successful, usually 401, 404, 500 etc. Checking the screenshot is usually sufficient but if that does not reveal anything, you can check the waterfall and execution log (see Synthetic Player (VUP) logs section here)
Does anyone has experience with “NAME_NOT_RESOLVED” error? I have no idea the root cause of this error
@Quirina “NAME_NOT_RESOLVED” means that the domain name you are using in the monitor cannot be resolved to an IP Address by the DNS resolver.
I recieved the error 12033:
| 12033 | The site reported ERR_TIMED_OUT | Yes | Chrome net error | Since sprint 168 |
Does anyone of you got it before? And what to do about it?
This means the request timed out. What happens if you try to curl to the endpoint from the Activegate? Try the troubleshooting here
