10 Old Versions of OneAgents - Can that number be changed?
Greetings,
After doing some research, I found that by DEFAULT a server with the OneAgent holds on to 10 previous versions.  With the 11th being the active / latest version.
Is there a way for it not to hold so many old versions?  It is quite a bit of space when you have thousands of servers.
Looking for a config parameter that could be change to something like 3 older versions being held on the server.
Matt
Hi @mmevanson
I see only one option. If you want to change it, you should open a Dynatrace support ticket to have the aging mechanism adjusted.
Radek
Why does it keep old versions anyway? There’s no rollback feature yet
