Hello, Developer Friends
Welcome to the 34th edition of our latest newsletter. In it, we cover essential updates, useful resources, upcoming events, and the latest releases.
What can you expect to see in this post:
News and events
Engage and elevate
Using AI to build Dynatrace apps was the highlight of the Dynatrace Office Hours for App Development on March 9; as usual, we also shared the latest updates and releases and answered your questions about developing Dynatrace apps.
If you couldn’t join us, you can rewatch the session on our Dynatrace YouTube channel.
On May 11, we’ll hold our next Dynatrace Office Hours for App development session, so stay tuned to sign up on LinkedIn.
Useful updates
Speed up your Dynatrace apps with code splitting
Large JavaScript bundles slow down your app’s initial load. We’ve published a comprehensive guide to help you optimize performance through code splitting—breaking your app into smaller chunks that load on demand.
What you’ll learn:
- Route-based splitting—Load only the code needed for each page
- Component-based splitting—Defer heavy components like charts and editors until they’re needed
- Dynamic imports—Load utility functions and libraries on user action
- Best practices—Keep your main bundle under 1 MB for fast startup times
Getting started:
Code splitting requires dt-app CLI version 1.9.0 or later with the --optimize and --enable-code-splitting flags. The guide walks you through converting static imports to lazy-loaded routes using React.lazy() and Suspense, and provides practical examples for splitting components and utility code.
Read the guide: Code splitting
A faster, lighter Strato DataTable
The DataTable component is one of the most critical in our product ecosystem. Over the last months the Strato teams introduced several improvements, resulting in:
- Up to 60% faster render times and over 40% lower memory usage.
- A 98% reduction in retained memory, which now stays stable regardless of how long the table is used.
- Support for unlimited datasets, removing the previous 10,000-row/column limit.
- Improved virtualization logic, leading to fewer re-renders and much smoother scrolling.
Get the improvements:
Enhancements have been rolled out gradually. To get the full set of changes, upgrade to version 3.0.0 of @dynatrace/strato-components
Prepare for Strato Components 4.0.0 breaking changes
Heads up: Strato Components 4.0.0 is on the horizon with several breaking changes. Now’s the time to review your apps and check if you’re using affected features.
Key changes coming:
- AiLoadingIndicator—
aria-disabledprop will be removed - AppHeader—Deprecated navigation items (like
AppNavLinkandNavItems) will be removed; useAppHeader.LogoandAppHeader.Navigationinstead - CodeSnippet—
allowCopyprop replaced withshowCopyAction - DataTable—Multiple deprecations including the
datecolumn type (usedatetime),linkoption oninteractiveRows(useonActiveRowChange), and legacy test mocks
What to do:
Review the full list of breaking changes to identify if your apps use any of the deprecated features. Where possible, migrations will be provided to help streamline the transition when 4.0.0 releases.
Learn more: Upcoming changes in Strato
Build a Dynatrace app with AI in minutes
Watch Andi Grabner and Dani Coll demonstrate how to build custom Dynatrace apps using AI coding agents—no prior coding skills needed.
What you’ll see:
In this video, they walk through a practical example that turns Dynatrace logs and business events into an interactive app for detecting suspicious trades. You’ll learn how AI agents combined with the Dynatrace App Toolkit can generate UI and backend logic while you focus on the domain logic.
Topics covered:
Build apps from scratch using the App Toolkit, generate code with AI coding agents, query business events with DQL, use Strato components for consistent UI design, validate DQL queries and components with MCP servers, and extend observability beyond dashboards with domain-specific applications.
Watch now: Build a Dynatrace App with AI in Minutes
Release highlights for app developers
Design System
Catch up with the latest enhancements to the design system. The latest changes are available on the Strato - Release notes page.
Catch up with the latest improvements to the App Toolkit. You can find the latest changes in the annotated release notes.
If you’ve enjoyed this post, please give us a thumbs-up (or kudos!) and let us know in the comments what topics you’d love to see in our next newsletter. Your feedback is valuable input for our content. Thank you for reading!
