ActiveGate has a counter metric cache that transforms monotonic counters to delta counters, for cluster scalability reasons. This cache, by default, currently allows 100.000 entries and AG rejects some counter metrics when the limit has been reached.
Symptoms
You enabled monitoring of Prometheus metrics and missing some metrics which type is counter. In the AG logs, you observe the following warning message:
<timestamp> UTC WARNING [<environment-id>] [CounterCacheImpl] Counter metric cache limit exceeded: 100000. Data point evicted. Reason: SIZE [Suppressing further identical messages for 1 hour]
Resolution
There are two possible options to overcome the problem.
1. Filter ingested metrics and exclude unnecessary ones
2. Extend the cache limit parameters in the custom.properties file
Example:
[kubernetes_monitoring]<br>mint_metric_counter_metric_cache_size=300000<br>mint_metric_counter_metric_cache_expiry_duration_minutes=2
For containerized AGs, deployed via the Dynatrace operator, enable the same configuration in the dynakube.
activeGate:<br> ...<br> customProperties:<br> value: |<br> [kubernetes_monitoring]<br> mint_metric_counter_metric_cache_size=300000<br> mint_metric_counter_metric_cache_expiry_duration_minutes=2
