I was wondering if the account management audit logs are also queriable through DQL within Dynatrace by a properly privileges (admin) user instead of API or UI access as documented here:
The idea would be to initiate a workflow every time a platform token is created, so we can do some remediation checks on it. We do the same with Openpipeline from which the logs come in dt.system.events but the account management audit logs seem not to be querable through there.
