Activation of Deep monitoring for GO
Hi Folks,
I have found a Go application in OpenShift (redhat costmanagement-metrics-operator) with inactive deep monitoring because of rule 47.
Is there any connection between rule 47 and Go monitoring settings second item?
Does rule 47 override the Go monitoring settings second item? Or there is not connection between them?
Does anyone have experience about this topic?
Thanks in advance.
Best regards,
Mizső
Hi. Both settings are connected. In order to monitor Go statis processes:
  • In Settings the option “Enable Go static application monitoring” must be enabled.
  • Rule #47 must be disabled.
Also there is in Host settings a Go section where you can enable Go statisc monitoring only on individual hosts. Also in this case is needed to disable Rule #47.
Hi @joseandrescalvo,
Thanks very much for your explanation and help.
Best regards,
Mizső
