ActiveGate extension icon
Hi, I’m developing an ActiveGate extension and since my active gate doesn’t have internet access I’d like to retrieve “favicon” locally (i.e. from a predefined location on active gate server, for example /opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.myplugin
I tried to set
“favicon” : “/opt/dynatrace/remotepluginmodule/plugin_deployment/custom.remote.python.myplugin/icon.png”
but it doesn’t work.
Is there a wat to achieve this?
PF
The favicon is fetched by the Dynatrace cluster, not by the ActiveGate and then the icon is cached and served to the user.
I see, thanks, so I’d say no chance to achieve this, right?
Correct. In Extension Framework 2.0 you’ll have more possibilities, mainly the use of any icon from Barista: GitHub - dynatrace-oss/barista: Barista - the Dynatrace design system. Tailored to scale. · GitHub
Mike
Putting the icon somewhere on a public site is the most comfortable way (github for example). If your cluster is airgapped, then it depends on your environment. Just any web server your cluster can reach is OK.
Thanks a lot!
Thanks for sharing about this tool, it looks great for adding more flair to custom extensions.  I was looking through the Extension V2 documentation, but didn’t see how to use one of the icons from Barista.  Is there any documentation on what needs to be added to the extension.yaml file?
Hi guys,
Any updates on @wmyers question on how to add icon to EF2 ?
We can see svg file with in extension zip, for example:
Question is how to add the svg file when we create extension with vscode?
Thanks in advance
Yos
As far as I know there is no plan to support custom icons anytime soon. I don’t think that svg is used for anything.
