ActiveGate not connecting to cluster, checked the TCP port connectivity. required services are running.
I would raise a support ticket.
Best regards
What information do you have in the ActiveGate logs?
Hi @vajrababu1976
You did not install the AG from the configured environment. Installation must be performed from the CMC due to the connection requirements.
Alternatively, follow the documentation.
