ActiveGate requirement for Synthetic Monitoring
Hi Friends,
I’m a bit confused about the Synthetic Monitoring setup. Is it MANDATORY to install a separate ActiveGate for private synthetic monitoring, or can we use an existing ActiveGate by enabling the Synthetic capability/extension?
Support recommendation is separate AG but not convince/clear why it is. please suggest.
Thank you,
Synthetic ActiveGate must be installed separate, it should be dedicated to run Synthetics checks.
Best regards
