I have a requirement to create a dashboard panel to show the newest date for a particular log entry and highlight it, if it’s older than today’s date.
I’ve created a panel that pulls this information via the following DQL into a single value panel -
fetch logs
| filter //some filter criteria
| summarize max_timestamp = max(timestamp)
This shows up as the following panel in the dashboard.
Now, in order to highlight the text in red if the date is less than today’s date, I went to the thresholds but could not find a way to select the variable to set this.
How can I set a threshold for the timestamp value to show up in red color if it’s older than today’s date?
Thank you!
