Hi All,
I have configured a Apache Kafka extension and its collecting the data.
Now I want to add all entries related to this extension to my existing MZ so that I can filter metrics data in data explorer wrt to this MZ only.
Please guide.
Guru Gogi
I think you need to develop your own script using Dynatrace API.
Best regards
Hi @AntonPineiro ,
please can you explain more like which API and how to use it.
Hi @gurugogi
In Dynatrace, there are APIs that can directly tell you the names of individual entities you want to add to a Management Zone (MZ).
The configuration might then look something like this.
{ “enabled”: true, “type”: “SELECTOR”, “entitySelector”: “type(QUEUE),toRelationships.indirectlySendsToQueue(type(SERVICE),tag(\”[Environment]DT_RELEASE_STAGE:{{ .stage }}\“))” },
where you can use linking based on the tag level of the monitored services.
I would say a combination of monitored entities to filter entities to management zone scope. And Extensions 2.0 for adding those to Kafka extension.
Best regards
