Hi @Vijayt
I thnik you can use for this the entity selector and tags. Lets assume you have 4 tags for 4 groups.
pgn:antivirus, pgn:apache, pgn:osprocess, pgn:scanning. Use the automatic tagging by rules or manual tagging ( not recommendded).
Metric expression could be:
builtin:tech.generic.cpu.usage:parents:filter(and(or(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“pgn:antivirus~”)”))))):splitBy(“dt.entity.host”,“dt.entity.process_group_instance”):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“pgn:apache~”)”))))):splitBy(“dt.entity.host”,“dt.entity.process_group_instance”):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“pgn:osprocess~”)”))))):splitBy(“dt.entity.host”,“dt.entity.process_group_instance”):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“pgn:scanning~”)”))))):splitBy(“dt.entity.host”,“dt.entity.process_group_instance”):sort(value(auto,descending))
I use partition transformation for value partioion only eg. from the documentation:
:partition(
“Action duration”,
value(“slow”,gt(200)),
value(“fast”,lt(100)),
value(“normal”,otherwise)
I hope it helps.
Best regards,
János
