I think that this is expected with Segments.
In Dynatrace, a Segment is enforced via its “Includes”. If your selected segment doesn’t include the data type you’re querying, the result becomes empty. Dynatrace docs explicitly state that querying data not referenced by any include leads to empty results. Include data in segments
You use fetch bizevents, so if the segment only includes (for example) metrics/logs/entities but does not include bizevents, the Guardian validation events will be filtered out.
I think you need edit the segment and add an Include for Business events (bizevents) that matches SRG.
Remember that includes are ORed, so this will keep your segment scoping while also allowing SRG validation events through.
If you’re using a Lifecycle guardian, validations might be written to events, not bizevents, so add a second include for Events as well or use an “All data types” include if that fits your model.
Yep, I’ll stick to my guns here. You’re not missing a “Guardian entity”.
SRG (Business Guardian) validation results are written as Business events, so when you apply a Segment, the tile will only return data if the Segment includes the bizevents data type. If your Segment currently includes only entities/metrics/logs, then any fetch bizevents query will go empty once the Segment is applied.
So the fix is to edit the Segment → add an Include for Business events (bizevents) that matches SRG, e.g.:
event.provider == “dynatrace.site.reliability.guardian”
For Lifecycle Guardians specifically, results are written as Events (SDLC), so you’d add an Events include instead (not an entity). Look here in documentation: Site Reliability guardian event structure
eg. from documentation:
