So basically I want to get the current metric value when the static threshold is exceed in a custom metric event, in the body of the email alert. Ik there are placeholders that we can use but I wasn’t able to find anything for the current value. Can someone please help out?
I suggest preparing a Metric Event and defining an alert profile based on it. You should then get the value of the metric at the time of saturation.
Hi @aades_kanna
Have you managed to solve the problem? It would be great if you shared the solution with the Community users ![]()
Use {severity} … I dont know why its this, but it seems to work.
