Advanced query to get request with response time less than 4 secs
Hi Niharika,
You can create a query in MDA and from there, creating a calculate service metric:
Hope it helps.
Elena.
Hi Elena,
Thank you for the solution. I am able to get the count. Can you suggest how to get it in data explorer, as I need to add it in a dashboard.
Niharika
Hi Niharika,
Once you create the calculate service metric, you can find your new custom metric in Data Explorer, show the data in Data Explorer, and pin to Dashboard.
I hope my explanation was clear. If it wasn´t, let me know.
Elena.
