Aggregate load and XHR actions
Hello, to measure user activity, I need to make a chart in which to aggregate all actions. The problem is that the same actions can be performed through different fields. and one action is like a XHR action or Load action.
There is a way to visualize them in a dashboard, but it shows the result in different columns on different rows.
How can I aggregate the result in one row in one column to show aggregation of load and XHR action.
Hi @Adrian_Kefirov
You should to use below metrics and split by Browser or Web Application
  • Action count - load action (by browser) [web]
  • Action count - XHR action (by browser) [web]
Radek
Hello @Adrian_Kefirov, did Radek’s suggestion solve your issue maybe? If so, you can accept it as a solution to let others in the Community know it’s been resolved :wink: thank you!
Yes, of course Ana, but can I back from a vacantion :face_savoring_food:
It is not a solution, values are still in different columns…
I tried something like this, but looks like the syntax should be different:
builtin:apps.web.action.count.load.browser:splitBy(“dt.entity.application_method”):sort(value(auto,descending)):limit(100) +
builtin:apps.web.action.count.xhr.browser:splitBy(“dt.entity.application_method”):sort(value(auto,descending)):limit(100)
