Hi, there
Is it possible to generate problem when a specific mount point goes missing after server reboot?
Srikanth Samraj
Hi, there
Srikanth Samraj
Hi @SrikanthSamraj,
Maybe you can use this extesnion.
Filesystem monitoring monitoring & observability | Dynatrace Hub
“Check if /data/mount-data is mounted
Select check type = mount point
Path = /data/mount-data”
I hope it helps.
Best regards,
Mizső
Thanks much for the insight, @Mizső . This is helpful.
I’d be glad if there’s an option via metric event or anything else without the need of using extension.
Product idea has been raised → https://community.dynatrace.com/t5/Product-ideas/Alerting-for-missing-mount-point-in-AIX-platform/idi-p/255022
