Alert when Node Down
in the 3-node HA model. If a node down, where will the system warn?
Email right? And how to config it?
Hi @tuanla123,
I hope it helps:
Best regards,
Mizső
Unless you are in the updgrade process of the cluster you should get an email.
You can check and configure it under Settings > Email > Email Notification
Please check also this link
