Does Dynatrace generate any predefined event when an ActiveGate goes line just like it does for oneagent?
Hi @SrikanthSamraj ,
I think you can use this metric:
And generate a metric event to notify you in case the number of OneAgent modules connected was 0.
You have these metrics for AG that you can see in demolive tenant. These help you to monitor AG.
Hope it helps.
Elena.
And also, you can install OneAgent in the ActiveGate, in inframode, and alert when proceses or OS Services are not up and running.
Best regards
