I have a graph set to detect 401 on a alert profile. I’m hoping to create a alert based off this? Any advice?
T
T
You can dot it using Metric Events: Metric events — Dynatrace Docs
Example:
Metric: dsfm:server.notifications.problem_notifications
You can filter by a specific alerting profile, integration type, etc or let it generic, with filter by RC only.
Try and let us know.
Thanks for the advice, did it in metric selector instead. Im trying to get it pick up on a alert profile so i can send to a slack channel, figuring out how to tag it.
