Alerts suppress of disk usage
I want to suppress the disk usage. i have got the 9 problem related low disk space i want to suppress All 9 problem into the 1 problem. i have gone through disk usage suppress but i can not find the multiple alerts suppress into the single alerts
Can you provide more details? If I understand correctly, you can different disks usage problems in same machine for different partitions/filesystems and you want to get only 1 problem?
Best regards
Hi @ishwar_jadhav1
Have you managed to solve the problem? It would be great if you shared the solution with the Community users :light_bulb:
it can now possible using disk rule
