Hi All!
I understand AppMon can analyze the code level of Java batch process.
So is Dynatrace possible to analyze the code level of java batch process?
If it is possible, what setting do I have to set?
If there are the following java batch program code, do I only set “func01” and “func02” method to “Custom service detection” of Dynatrace setting?
===== Sample Java Program Code =====
public class BatchTest {
public static void main(String[] args) {
func01();
func02();
public static void func01() {
// Batch main func 01
System.out.println("Batch main func01 ");
testSleep(10000); // sample processing
public static void func02() {
// Batch main func 02
System.out.println("Batch main func02 ");
testSleep(3601000); // sample processing
public static void testSleep(int ms) {
try {
System.out.println(" [testSleep stop "+ms+“msec]”);
Thread.sleep(ms);
System.out.println(" restart");
} catch(InterruptedException e){
e.printStackTrace();
Yasuo Ohnishi
