We want to get alerted on anomalous behaviour in our 4XX errors. In the particular, the ones affecting out front end and middleware.
Constraints:
We do not want to define 4XX errors as server-side as this will affect the failure rates and cause poor error detection to the mix of business/expected errors inherent to 4XX responses.
We want to minimize the number of CSMs and Metric Events, including the volume of data ingested by a Metric Event
Any solution has to tell us which application, service & HTTP response code is driving the issue (ie dimensions to split)
- Preferably we can drill down the specific request/endpoint
Preferably, when an increase in 4XX errors occurs, a solution would be able to tell us what request/endpoint is driving the issue.
Strong preference for anomaly detection vs static threshold
Any suggestions for the recommended solution to the above problem statement in Dynatrace Classic, we do not have Grail/DPS.
Hari
