Ansible Tower integration: compatibility with Workflow Templates
We are trying to integrate Dynatrace with Ansible Tower.
To integrate both it’s neccessary configurating the job template URL.
But our URL is a job ID that belongs to a workflow job template. This is the URL: https://xxxxxxxxxxxx/#/templates/workflow\_job\_template/xx
Our question is: is Dynatrace compatible with Workflow Templates to integrate it with Ansible Tower?
Thanks in advance.
Elena.
Yes, its compatible.
Look at the documentation.
You can transform your message the way it fits into your workflow template
