any possibility of running only one metric event
for remote unix metric events i want to have two disk events 1.  warning  > 70%  and critical >90%
i can use metric key event with above 70%  and  another event with  90% .
but  if directly filled from 60%  to 95% . then we will get both  metric event get executed and get two problems.
1.  how to stop evaluating two metric event
2. how to specify condition that will generate one problem
Hi @Vijayt
Check this out: Solved: Staged Disk Alerting - Dynatrace Community
I would say explore davis anomaly detection, if you are in Grail, for adding DQL queries to your needs.
Best regards
unfortunately we have only classic dashboard ONLY . no DSQL
  1. I can see thread is solved, is that correct?
  2. Are you in managed?
Best regards
yes
