Any way to do RUM-based page object trend analysis?
We can see the individual page object response times for a particular user session / page hit, but I am unable to find out how to convert that into an overall trendline (i.e. - what’s the average / min / max response time, CPU, etc utilization of homepage component “identifyuser.jsp” over a 7 / 14 / 30 day timeframe)?
Is this possible via Dynatrace RUM?
I think, that you can’t do such a detailed report in Dynatrace. However, in our clients we used build-in integration with elastic search to build complex reports. The integration is fabulously simple and you have full control over the data.
Radek
Relatively new to Dynatrace (coming from a background with a competing RUM service), can you point me to a link with an example of what you are describing please?
I guess this is what Radek is referring to: Export user sessions in RUM Classic — Dynatrace Docs
Correct me if I’m wrong :slightly_smiling_face:
As @Radosław J. said, exporting data to elasticsearch is one of the options. The second is using dynatrace API for adwanced user session queries:
https://www.dynatrace.com/support/help/monitor/use…
Elasticsearch approach is better for long therm analysis because you can control data retention by yourself. If you want to create reports for larger time period than couple of days/weeks, exporting whole data to ELK will be domething for you. There you can script data hendling and present it in kibana according to your needs :slightly_smiling_face:
Thanks for the link! Will pursue both options with the team and see where we end up, appreciate it!
