Need to deploy one agent in multiple servers using Automation tool. Is there any any way or any API which can be used. As there are 100+ servers which require oneagent to be deployed, doing it manually will take lot of time.
Your Dynatrace environment offers a convenient REST API for OneAgent download. You can easily trigger that by using a command line or shell script and automatically download your preconfigured OneAgent.
Most customers use this API to automate the agent deployment within their pipeline tool of choice, such as Ansible Tower.
