See below picture from same application,
Who can explain above tiles?
KR Henk
Left screen presents, that APDEX on mentioned country is higher than 0.85 which is ok. Seconds represents active session number from some other countries.
You are asking about difference in mentioned areas?
Hi Sebastian,
Both are overall pictures, so no filters. So the question is why is there no apdex in all other countries,
KR Henk
When you go into map details, there are still no data for wider scope? It may be because differences in number of visits I suppose.
Hi Sebastian,
You are right, there are 100 times more users from the country, so Apdex does not show the rest. Number of sessions is a number so that shows the worldmap!
Excelent, thx!
