API of /entities/{entityId} does not return all prorepties for my CUSTOM_DEVICE
Hello
I issue - API of /entities/{entityId} does not return all prorepties for my CUSTOM_DEVICE
1. I created my  CUSTOM_DEVICE
i used the required prorepties
  • ID -CI000000
  • system -SystemA
  • test - test
2**. prorepties** appeared in UI
3.  I used api /entities/{entityId} to get information about my  CUSTOM_DEVICE
4. the result did not show my property
5. I used the flag “field” according to the doc
the result gave an error (although the UI shows that I have a property “test”)
conclusion that api does not work quite correctly
Could please tell me on this issue?
Do I need create RFE?
There is already an RFE for that. I ran into the very same issues.
