Dear All,
According to the documentation. API Edge for Private Cloud is not supported at this time.
Do we have any alternative way to monitor using Dynatrace or 3rd party but to display/analyze the data by Dynatrace?
Babar
Dear All,
Babar
@diego_morales Can you share your knowledge here please?
I posted a reply to a similar question here:
https://community.dynatrace.com/t5/Dynatrace-Open-Q-A/Monitor-APIGEE-on-Dynatrace/m-p/182440#M20204
I also have an update. We’ve deployed Dynatrace to Apigee Hybrid and are monitoring this containerized version of Apigee.
@Babar_Qayyum , there are a few solutions out there.
Depends on which solutions they are more inclined to use, you can opt for any of those. If you need that EF 1.0 extension, let me know but I would suggest trying with the EF 2.0 first to see if it covers their needs. Or if they already have JMX configured on the Apigee side, you could do that much quicker.
Diego
Hello @diego_morales
If we go with option one, do we have to use the Apigee Edge extension? How exactly will this be achieved?
Babar
