AppEngine - WebSocket
I was interested in the ability to integrate chat functionality in an App built with AppEngine; is it possible to use websockets?
E.g. I would do something like this:
import io from ‘socket.io-client’;const socket = io(‘my-socket-io-server.com’);
export const App = () => { /* do something */ }
Thanks for the support.
Hi @fabbrus,
Thank you for your question. I’m checking if it’s possible to use the package you mentioned and will get back to you as soon as I can. If using the package is possible, you’ll need to use it in an app function, which will allow you access to external resources.
Kind regards,
Sarah
Hi @SarahFaustmann ,
Thanks for your kind answer.
Based on your reply, then I don’t think it is possible to use websockets, since for the chat a websocket needs to stay  open for as long as the user interacts with the app; but in app functions there is this requirement:
Runtime limitations​
Currently, the following restrictions apply to functions:
  • Function execution times out after 120 seconds.
So, the websocket would stop working after that time.
I’ll wait for your feedback, though.
Best regards,
Simone
Hi @fabbrus,
I’ve checked with an internal team. Unfortunately for your case, WebSockets are not supported for security reasons, and any third party module using them won’t work properly. I hope this answer at least saves you some further inquiry. 😉
Kind regards,
Sarah
