Hi DT Community!
We are trying to define application for certain Domain (one) / URL’s (multiple) but we are failing so far.
Configuration: we habe multiple applications which use same domain but different URL’s:
https://extranet-dev.login.companyname.org/application1/…
https://extranet-dev.login.companyname.org/application2/…
We are trying to define application(s) to catch them.
However, definition per URL (All URLs starting with https://extranet-dev.login.companyname.org/application1 ) does not work: If we use validation it identifies it properly, but de facto traffic keeps going to Default application.
We habe urgent action to do on extranet and need to deactivate RUM for it, so we decided to define application Extranet to put all of them in one bucket. However, none of these works either:
Domains that equal extranet-dev.login.companyname.org
All domains containing extranet-dev.login.companyname.org
All domains starting with extranet-dev.login.companyname.org
All URLs containing extranet-dev.login.companyname.org
None of them seems to work ![]()
We have some other definitions based on Domain that equal and some of them work.
Any ideas what is going on here?
Thanks!
Ingrida
