Application monitoring Cobol/C++ SOA
HI , can we monitor Cobol/C++ , SOA application through OneAgent? if so , what metric can be monitored.
By default, such applications are monitored only as a process, so you will see network traffic, cpu, memory per for each process. You will not see transactions. For C++ there is option to instrument apps using ADK (you need recompile app with injection implemented). Dynatrace OneAgent
