Hi Folks,
Is it possible to application process out of memory alert in DT SaaS? I’m specifically looking for Java applications.
AK
Hi Folks,
AK
wouldn’t that fall under the Java process running on a host, if the host and or process runs out of memory it will automatically alert you based off of the resource alert rule on an alert profile.
Correct @ChadTurner , automatic alert will suffice.
