Application running on ORACLE Tuxedo
Hello.
Would it be possible to monitor an application (Let’s say a JAVA application), that is build and runs on ORACLE Tuxedo?
https://www.oracle.com/middleware/technologies/tuxedo.html
Has anyone a similar experience?
Thank you.
Thodoros
I don’t believe that it is possible to inject an application Full Stack in Tuxedo. The maximal result you would be able to get is infrastructure monitoring combined with a self developed activegate extension to get extended metrics.
This would be host performance, monitoring of logs that you forward to dynatrace and metrics you pull from an api.
Thanks @michiel_otten for your reply.
That is my guess too.
BR
