Hello everybody.
I’ve been using the ‘Custom multidimensional analysis’ to get the ‘Request Count’, filtering by Service types and by custom ‘service tags’ and ‘process group tags’, and spltting by dimension {Request:Name} to successfully get a list of top web request.
Now , I would like to narrow my querry a bit more by using a request attribute (yet to be done) as value to narrow the filter.
The results I’ve got so far look like these:
/bi/eu/checkout
/health/probe.html
/ma/ca/ginbi/1/authentication/loginInfo
/bc/ca/ginbi/1/authentication/loginInfo
preferences
/lu/ga/checkout
I would like to create a request attribute called ‘region’ that would use the following regex:
^/([a-z]{2})/
Which means that in case the request looks like this:
/**/co/whatever → It will get the value of the two characters between the 2nd and 3rd ‘/’ character.
By doing this. When for example filtering by: Request attribute: region = “ca” --> it should only return:
I’ve tried unsuccesfully different approaches by using these datasources:
Capture Web request URL path globally
Capture Web service method name globally
Capture Web request URL globally
But I only see the request attribute created and attached to traces but not to web request.
It is possible to get this done?
Any help about whjat can I be doing wrong?
Thank you in advance.
Hi @CarlosTF ,
I just want to confirm if I understood correctly, based on your message, the request attribute has been created and is being captured successfully, and you can see it in the traces. However, you’re looking to include this request attribute in the request name, correct?
If that’s the case, you can achieve this by creating a request naming rule that utilizes the request attribute.
Let me know if that helps or if I misunderstood anything.
Hello @CarlosTF
Kindly review the attached Dynatrace resources:
BR,
Peter
Hi @CarlosTF
Kindly check the configured Oneagent headers features, make sure the required headers are activated and enabled properly, Thanks.
Hi @CarlosTF
if possible kindly share a configuration sample for further analysis, Thanks.
Hello @CarlosTF
PFA screenshot for validation
BR,
Peter
Hi @CarlosTF
in addition to the available resource, kindly make sure that Dynatrace headers aren’t blocked through Firewall or Network devices as per Infrastructure pass-through requirements for RUM Classic — Dynatrace Docs
BR,
Peter
Hi @CarlosTF
PFA Dynatrace ref as it contains related information to the current scenario:
Kindly keep us posted.
Hoping it helps,
BR
Good morning and thank you Peter, Mohammed, and everyody who tried to invstigate or answer this.
I’ve finally got it working when setting it like this:
Data type → text
All disticnt values
To upper case
Allow this request attribute to access unmasked personal data. (Enabled)
Add new datasource:
Request attribute source: Web Request URL Path
Specify where the attribute is captured and then stored: Capture from both client ans server side and store where found.
This worked.
Thank you all again
Em
Thanks @CarlosTF for keeping us posted, Best of luck during upcoming challenges and solutions :dynaspin:
No, thanks to you guys:
I forgot to add something
Data type → text
All disticnt values
To upper case
Add new datasource:
Also in the ‘Further restrict or process captured parameters (optional)’ section:
Prune whitespace: Enabled
and
Extract value from captured data per regex: ^/([a-z]{2})/
This time, this is the right solution.
Thanks again
